Charles in Aus.
I have taken the top tank off a 1953 Ferguson tractor radiator to clean and repair the core . All seems to be going well with the brass tank cleaning up well and the core having only a few small leaks .
What to use as solder and flux to re solder the tank back into position is the question , I have soldered before but mainly electrical work and on lead light windows with an electric iron .
I have a decent propane torch and usually use a 50/50 mix tin- lead solder with tallow as a flux . This works reasonably well in most applications but I think I may need a flux that is a little more aggressive and perhaps a slightly harder solder . Suggestions are very welcome .
