Texasmark1
I guess this is a tool. Anyway, I have a wind blocking fence of cedars. Tops are 35 ft high. In the next couple of months, something will come by and deposit eggs which develop into bag worms. Reading up on the subject apparently the source is deposited in the upper most branches of the cedars and the bag worm eggs fall down the tree limbs to infiltrate the whole tree. If you don't kill them they will kill the tree. Have seen it happen to a neighbor. I need my tree fence.
I have tried several pumps and spray wands, most made by Fimco. Currently my largest is 12v, 60 psig @ 2 gpm rating.....but you know as well as I those are extremes and don't occur simultaneously.....it'll put out 60 psig static pressure before the switch turns the pump off and if you're lucky, you might get 2 gpm out of it at who knows what kind of pressure.
I'm using a $50 pistol grip wand now and it's not what I expected. I want a pencil stream that will shoot 35' almost straight up hopefully with my current pump. This sprayer is a sink hole for money and a sink hole in desired performance.
What do you guys use for such a problem?
Thanks,
Mark
Thanks,
Mark
