(quoted from post at 16:32:53 02/23/15) How do you deburr the bar?
(quoted from post at 19:26:33 02/23/15)
Is the saw kept where it's warm and does the oil issue start after it;s been outside or all the time?
Deburring is just running a file at an angle along the edge of the bar where the burr builds up. [b:01ce7b94df]Bars are tempered, but not "hardened" [/b:01ce7b94df]and cut pretty easy with a decent file.
(quoted from post at 15:42:19 02/23/15)(quoted from post at 19:26:33 02/23/15)
Deburring is just running a file at an angle along the edge of the bar where the burr builds up. [b:93b2737c1a]Bars are tempered, but not "hardened" [/b:93b2737c1a]and cut pretty easy with a decent file.
[b:93b2737c1a]Tempering[/b:93b2737c1a] is a process of heat treating, which is used to increase the toughness of iron-based alloys.[b:93b2737c1a] Tempering is usually performed after hardening, to reduce some of the excess hardness[/b:93b2737c1a].
(quoted from post at 13:37:47 02/24/15)(quoted from post at 15:42:19 02/23/15)(quoted from post at 19:26:33 02/23/15)
Deburring is just running a file at an angle along the edge of the bar where the burr builds up. [b:26fa3b3ba2]Bars are tempered, but not "hardened" [/b:26fa3b3ba2]and cut pretty easy with a decent file.
[b:26fa3b3ba2]Tempering[/b:26fa3b3ba2] is a process of heat treating, which is used to increase the toughness of iron-based alloys.[b:26fa3b3ba2] Tempering is usually performed after hardening, to reduce some of the excess hardness[/b:26fa3b3ba2].
Jiles, not to argue, but I've never seen a bar I couldn't deburr with a decent file. "Hardened" implies that it's going to be tough to cut with a file or drill. They aren't hardened. Some aren't even tempered at all I don't think. If you can't deburr with a file, the file is probably shot. A belt or disc grinder works fine, but some folks tend to go way too far with power tools. That's why I recommend a file. Usually all you have is a tiny burr that's a 5 stroke problem to fix.
(quoted from post at 15:52:01 02/24/15)(quoted from post at 13:37:47 02/24/15)(quoted from post at 15:42:19 02/23/15)(quoted from post at 19:26:33 02/23/15)
Deburring is just running a file at an angle along the edge of the bar where the burr builds up. [b:8c17693290]Bars are tempered, but not "hardened" [/b:8c17693290]and cut pretty easy with a decent file.
[b:8c17693290]Tempering[/b:8c17693290] is a process of heat treating, which is used to increase the toughness of iron-based alloys.[b:8c17693290] Tempering is usually performed after hardening, to reduce some of the excess hardness[/b:8c17693290].
Where in my post did I say a file could not be used?
I guess, over the years, I have deburred hundreds of bars.
When I do a job, I try to do a thorough job. This included filing the top groove flat as well as deburring the corners.
Edge can be filed really easy with a file, but try to file the top flat.
I do not argue on a forum. I am a retired Tool & Die Maker and consider any metal that has been through a heat treating process to be hardened don't know what a bar would be on Rockwell Scale in hardness?
Interesting that you brought this up--never been questioned before.
We just have a different understanding of "Hardened Metal", but can still be friends.
