bobcat attachment for moving dead tractors
1948 mm
We have a s300 bobcat and were looking for ideas for moving around tractors that do not run. Ideally we could attach under the front axle to lift them and be able to push or pull them without running into the grills. Thank you
Make?? I you have the bucket on it you can slide it under the front tires on the trike type tractors and lift them up and push away. Done that many times over the years with my loader tractor. Tires hit the back if the bucket so you do not hit the grill
if you have a wide bucket 78 or 84 you can do that with the wide fronts as well, weld a chain hook on the bucket then the chain will keep the tractor from accidentally rolling out on the hills; a snow bucket works best as they are deeper buckets.
We weld chain hooks to each corner of any bucket we have so as to be able to lift stuff and chain stuff in
you could fab up a couple of bus fork type clamps. they use em on medium and hd wreckers for trucks and buses. these will hook on the axle. mount them on the top of the bucket and drive under and lift. the weight of the tractor will keep he axle from popping off the forks.
here is a link
poke here
I just use my forks. I blew a hole in one, and the hole goes under a bolt on the adjustable front end.
Make a push pole. One end pinned to the dead tractor drawbar and the other pinned to a hole blown in the pallet fork. Push the unit into the shop.
Ranch
