Chris Jones
My neighbor inherited one and has just started using it a bit. It's a model A catalog number 444-7. Now the head stock is starting to seize up. He wants to remove and inspect the headstock shaft. We can't figure out is how to remove it. It would appear to have bearing caps bolted down on top like an engine has them holding the crankshaft in, but those caps are not a separate piece there's only one bolt that just closes the hole a bit to clinch the bearings or bushing in. It appears the shaft has to be removed by pulling it out to the right but it would have to pull out through all the pulley's too. We don't know if it's splined or got a key-way or ???? Can anyone give us any advise on how to remove it? Thanks.
This is what the lathe look like from internet
