Chris Jones
I have 2 lawn tractors and a compact diesel here that I have float charger on to prevent the batteries from going down while not being used. I removed the leads today from one battery and tested across the leads with a volt meter. 9.6 volts. The manual says it should be putting out 13.2. I checked the others and they say 12.6 and 12.4 volts. All they have is an led on them that stays on when they are connected to the battery or plugged in.
Do these things go bad with age?
Do you reckon 12.4 or 12.6 is enough to be helping those batteries?
