Log splitter
NMace
New User
I have a Case IH 235 that I want to install the hydrolic log splitter sold by TSC, do they make a kit to use the 3-point hitch hhydrolics?
I built a very heavy duty splitter for my skid steer. It could easily
be converted to 3 point hitch. And it's for sale! Lol. I used it
for 2 seasons then got a divorce and moved, don't need it
anymore.
(quoted from post at 05:38:30 02/05/15) I built a very heavy duty splitter for my skid steer. It could easily
anymore.
Where is it located?
I'm not familiar with the model, and I assume its plug and play, and maybe you've researched it, however you may want to also make sure the tractor's hydraulics are compatible with the TSC (really Speeco) 3 pt splitter. There has been discussion of it on here before and one of the problems to be aware of, (may or may not apply) is to make sure the tractors hydraulics meets the needs of the splitter, flow, pressure etc. There has also been discussion of configurations, one issue is the valve or kind of valve, and creating heat. Its significant run time with repeat cycling so just good to know you have a match or need a simple modification, if at all even necessary.
