Hyd. Oil manual pump
Tequila
Looking for a hand operated pump with hose to attach to 5gal UTF container to fill transfer axle's and transmissions fluid. Several out there, but cannot determine quality. Anyone use these or have an idea of the best one to choose?
I have a cheap one that I bought at the local farm store. Fits over a 5 gallon bucket. Cost around $26 10 years ago, if my memory is correct. Has about a four foot clear hose. Works to my satisfaction. Probably made in China. I've only used it for 90W gear lube, so not sure how it will work with low viscosity fluids. I don't think anyone was proud enough to put their name on it, so can't help there.
I have had one for decades that I got from my O'Reilly's auto parts store. Cost around $50 back then and has worked just fine. Simple lid that has the pump in the center and a hose wit ha metal J hook on the end. If I knew who made it I would tell you but it has no name on it
I bought a brand new 20lb propane tank and turned it into a bleeder tank with home made pipes, pressure gauge, flow adjusting valve. Works great for gearboxes.
If it is the hand pump type you get a sore arm trying to pump a lot of 90w thru that small hose or maybe I am just getting old !!!
