dr sportster
Lanse , If this photo loading works . The first pic is a quick change tool post or tool holder. { you can see the China on it { no comment].To quickly change tooling you switch out the entire dovetailed piece and swing the handle , done. Next is a carbide insert holder which still has to go into a tool holder mounting block. The next photos of the tool holder that cuts off the end of the tool is the Diamond Tollholder . It comes with a tool grinding jig and is easy to sharpen. The last pic is a typical lathe project of a velocity stack for a carburetor.
