Another project just popped up that is going to have to move everything else down a notch.
The small wheels on my walker I use to do chores and go back and fourth from the shed and barn is falling apart from all the bumps. I need to whip one up out of one inch square tubing with my 24 inch wheels on the front and wide 8 inch on the back. I put a five gallon pail of water in the seat of my current one. With the large wheels on the front I can make a platform for two five gallon pails between the stub axles and still put a seat between the handles. It will not need to be folded. That is what is weak with the one I am using now. Jig and weld up two side frames and weld in about five cross pieces. Tack in some expanded metal to set the pails on. Tubing and two 5/8" bolts for axels is all I will need to buy. There it is, an old mans walker feed cart or walker garden cart by adding more cross pieces to form a basket.
