Thermal ARC 190. Search shows that new it is a $1699 welder.
Here is a copy of the listed data.
Processes: MIG, Flux Cored
Rated Output:
Wire feed speed: 80-700 IPM
Product Type: Arc welders/Mig welders/Flux core welders
Duty Cycle Percentage: 15pct
Duty Cycle Percentage: 30pct
Maximum Voltage: 208
Output Amperage: 190
Work Clamp Included: Yes
Generic Specifications
145Amp at 22V, 30pct Duty Cycle
190 Amp at 23.4V, 15pct Duty Cycle
Amperage range: 30-190 Amp
208V/230V/60Hz/1Ph
The auction picture shows a tall tank mounted on the back.
Some have advised to only buy a Name Brand welder like Miller or Lincoln.
For a person who is not going to use it real often, would this be a good purchase and how much to spend on it also??
Thank you
Steve
Rated Output:
208V/230V/60Hz/1Ph
Thank you
Steve
