John Deere 350B loader
I just had a 350B john deere given to me.It hasn't been running for 2 to 3 years and I would like information where I should start to get it running again. Any ideas would be gratefully appreciated
thanks Don
someone on the john deere forums could give you the best info. But in general,check out all of the fluids .was it sitting inside or outside ? If it was outside and not covered up make sure its free. Is it a gas or diesel ? wouldnt hurt to drain the engine oil and make sure there isnt any water in it . if its a gasser,maybe pull the spark plugs and shoot some atf into the cylenders to pre lube it spin it over a few revolutions clean,gap and reinstall the spark plugs . look at the gas tank. any rust and crud it there will give you headachs . fresh fuel antifreeze,oil, look at the battery is it charged,Good clean connections ? let her rip Good luck !
