wire feed welder at an auction
SDE
Thermal ARC 190. Search shows that new it is a $1699 welder.
Here is a copy of the listed data.
Processes: MIG, Flux Cored
Rated Output:
Wire feed speed: 80-700 IPM
Product Type: Arc welders/Mig welders/Flux core welders
Duty Cycle Percentage: 15pct
Duty Cycle Percentage: 30pct
Maximum Voltage: 208
Output Amperage: 190
Work Clamp Included: Yes
Generic Specifications
145Amp at 22V, 30pct Duty Cycle
190 Amp at 23.4V, 15pct Duty Cycle
Amperage range: 30-190 Amp
208V/230V/60Hz/1Ph
The auction picture shows a tall tank mounted on the back.
Some have advised to only buy a Name Brand welder like Miller or Lincoln.
For a person who is not going to use it real often, would this be a good purchase and how much to spend on it also??
Thank you
Steve
I don't know anything about that one, but I had a thermal arc back when I had my shop and it was a great welder. Welded nicer than the Miller's but was a bit less in the duty cycle. Should be a good welder.
Do not bid unless it is DIRT cheap, or you have been able to see it plugged in and working.
Check it out ahead of time if at all possible.
Not a knock on this welder, just advice from experience. I was lucky to learn from someone else's experience!
If you go to a store and buy a new one the name is now Victor. Sounds like they are a little high on the retail price quote, but still and good welder.
research
Steve;
I've heard that Thermal Arc products are good quality, but I second the warning about buying a wire feed welder unless you can try it first. To buy it at an auction (all sales final, I assume) is a gamble to some degree, and I'm not much interested in gambling. But that's a decision a person has to make for himself.
Several online retailers sell that welder for about $1025, with free shipping. I've included one link.
Let us know what you decide to do, and how it is if you end up with it.
Stan
Cheaper retail price
