Steve@Advance
Bubba wires up a 120v RV to 220V? Well, so far I've found the microwave is dead, the 12v converter is dead, the AC/heat wont work, the propane/electric water heater does nothing, the propane/electric refrigerator does nothing.
I opened up the microwave, it's not the fuse. That can be fixed with a trip to Walmart.
The 12v converter, I drilled out the rivets, took a quick look inside. Didn't see any fuses, didn't see or smell anything burned. It's a Parallax 55a, 7300 series. I can get a replacement Parallax for $218 on Ebay, or sub a Power Max 55a for $110. I'm leaning toward the Power Max.
I'm hoping the ac/heat unit and the water heater will come to life once I get the 12v working. Not holding much hope for the refrigerator though, but didn't check it, just no sign of any life. Probably end up replacing it with a small home unit.
All I need to get working is the electric. They don't use the propane system. This will never be used for camping, a struggling young couple is trying to live in it, so every penny counts.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
