I've got a Marquette and two Allens. All work pretty much the same. Here's instructions.
Here's my Allen with probes:
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=100_8592.jpg" target="_blank">
</a>
Growler instructions in text:
ARMATURE TEST.- There are two practical tests for locating shorts, opens, and grounds in armatures- the growler test and the bar-to-bar test.
To test for short circuits, place the armature on the V-block of the growler and turn on the current. With a thin metal strip (hacksaw blade is good) held over the core, as shown in figure 2-17, rotate the armature slowly through a complete revolution. If a short is present, the steel strip will become magnetized and vibrate. To find out whether the armature coils of the commutator are short-circuited, clean between the commutator segments and repeat the test. Should the thin metal strip still vibrate, the armature is short-circuited internally and must be replaced.
Not all armatures can be tested for short circuits by the method just described. These armatures can be identified by excessive vibration of the saw blade all around the armature during the test. With these armatures, test for short circuits by using the milliampere contacts on an ac millimeter, as shown in figure 2-18. In doing so, keep the armature stationary in the V-block and move the contacts around the commutator until the highest reading is obtained. Then turn the armature to bring each pair of segments under the contacts and read the milliammeter at the same time. The readings should be nearly the same for each pair of adjacent bars. If a coil is short-circuited, the milliammeter reading will drop to almost zero.
Test the armature for grounds by using the test light circuit, which is a part of most modern factory-built growlers (fig. 2-19). Place the armature on the V-block and touch one of the test probes to the armature core iron. Touch the other probe to each commutator segment in turn. If the armature is grounded, the bulb in the base of the growler will light. In contacting armature surfaces with the test probes, do not touch the bearing or the brush surfaces of the commutator. The arc would burn or pit the smooth finish. Replace the armature if it is grounded.
In testing individual armature coils for open circuits, use the test probes, as shown in figure 2-20. Place them on the riser part of adjacent commutator bars, not on the brush surfaces. If the test lamp does not light, there is a break some where in the coil. Repeat this test on every pair of adjacent bars. Do this by walking the probes from bar to bar. Should you find an open coil, the fault may be at the commutator connectors where it is possible to make repairs with a little solder. If a coil is open-circuited internally, the armature should be discarded
Growler instructions with pictures:
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=grrowlerpage1before.jpg" target="_blank">
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=growlerpg2.jpg" target="_blank">
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=grolwerpg3.jpg" target="_blank">
</a>
Here's my other big electric magnet- my magnet charger for magnetos :
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=100_8585.jpg" target="_blank">
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=Weidenhoff6.jpg" target="_blank">
</a>
