farmall 450 fan blade
woodsrider
New User
I am wanting to take the fan blade off of a farmall 450 with out removing the water pump.There is a piece on the end of the propeller shaft I am not familiar with.Does anyone no how the easiest way to remove it.
Pump driver, remove pinch bolt, might have to slide a screw driver into a slot to remove, can't remember, don't lose the 2 springs.
As you can see in the picture no5 is a tapered pin and you take the nut off and use a brass punch and drive it out. Then take no6 off and then you can unbolt the four bolts and the fan will come off. HTH
Bob
