clutch adjustment 575 massey furgunson
mickrowe
New User
i have 575 massey, is there another clutch adjuster other then the turn buckle under the floor plate ,my problem is when the clutch lever is fully depressed the PTO still spins,can i adjust the clutch to be able to stop or disengage the PTO shaft from spinning
Post down on the Massey (Massey Harris and
Ferguson) board, folks that hang out there have
probably done this task a time or two
Wisbaker has a good suggestion.
There are three adjustment screws on the PT0 clutch that will
need attention.
There are two clutch discs inside the bell housing, one for the
PTO and the other for the drive. Should only have to push
clutch pedal half way down to disengauge PTO.
PTO clutch adjustment is done through the inspection
cover under the machine on say a 65. I'm not
familiar with your model. If it is independent PTO
it probably has a brake. Best to ask down on the
Massey forum. Some good advice down there.
