Wielding by Braille 101
Grab the stinger and ground to see if you have current. If your still alive then turn wielder on and clamp ground to the part you want to wield.
Put your finger and wielding rod on spot wielding and when you finger starts to burn lift finger out of the way. when done wielding part ask someone if you started a fire. Then check your wield with finger, not burnt finger, if it feel as ruff as my wields you are doing better then I am because I can see and can't wield either... Dogs with no thumbs can wield better then I can... I'm almost sure of that.
That's why I call it wielding by Braille
Ha Ha
Fat
Ha Ha
Fat
