back blade modification
jon f mn
The back blade wouldn't work on my Case DC unless I took the drawbar off. That was a pain so I decided to modify it a bit. This is the blade before.
I cut out the front bar and moved it behind the pins so it would clear the drawbar.
The welds didn't turn out too good, my helmet was foging up and I couldn't see too good. I think it will hold tho.
I've also had problems with fogging.
I wonder if the defogging products for glass/windshields would help?
Dusty
