We built our new home a few years ago. This is the first time we have lived with central air and heat. We have a high energy unit and are happy as clams and warm. The question I have is about how the humidifier control works. It is made by General Aire model 1137. It has a control box that sets beside the furnace thermostat. It works independent of the furnace thermostat. Should this thing be hooked into the furnace control some how? It seems to me that it would do a better job if it only came on when the furnace is on. You can turn it on and it seems to have to run all the time to get the humidity from say 24% to 28% humidity. I don’t see how this humidifier unit can push that humid air thru all the heat ducts by its self. Is this normal? Water is on to it and the filter gets changed each spring.
