over/under,splining
looking for a machine shop that would consider a small job of splining a couple of shafts? And considering some form of coupling a high low range affair between engine and transmission to provide more shift ranges, the over/under Oliver device that they used on their 1600 and up tractors how adaptable are they? Thanks,dave
Untitled URL Link
You need a gear manufacturer to make splines. I have had Butler Gear near Milwaukee make splined stuff.
Regarding the hydra-power, it might work on something else. If you are talking automotive application, there might be RPM and cooling problems. They were self-contained but needs connection to cooling system.
