MasseyHarrisGuy
Has anyone used a product that can be used on threads on a nut or bolt to act like a ny-lock nut or a locking nut? I have a hydraulic pump on my tractor with a controlable flow and the needle screw that controls the rate of flow keeps backing off increasing the drop speed. I would like something that can be applied and stays put to act like a non permanent, non hardening "threadholder". I would need to set the speed after the valve is back on the tractor and in use.
Upsetting or deforming the threads on the needle scares me a little because its a steel needle in an aluminum housing.
Anyone had this issue before?
Thanks in advance
Frank
Thanks in advance
Frank
