140 carburetor cleaning
Bill140
New User
I have a 140 carburetor I need to clean. I have never done this
before. Any help?
Should I attempt this?
What cleaner should be used?
Bill, what tractor is it from ? JD Garden tractor or a farm tractor ? If Lawn and Garden tractor. Its not hard to do. Remove everything you can. Soak in berrymans carb cleaner overnight. Wash in hot soapy water then BLOW EVERYTHING OFF with compressed air. Reinstall everything and set the air/fuel screw about 1-1/2 turns OUT from seated. Should be close.
