Changing oil in post hole digger
well... 90 wt gear oil if no other info. do not fill too full as you need room for expansion when it gets warm.
If the seals leak, use 00 wt grease or cornhead grease.
Here is an excerpt I found in a manual. We can only post images and not .pdf files so if you want the whole user manual send me your email and I will send you the file.
