valve stems
Animal
what are the numbers for the valve stems in tubeless tires? I think the small hole is 413, what is the big hole?
For the larger hole: 415 would be most common. 425 is the longer version. 801HP is the high pressure one, and 802HP is the long high pressure longer one. Clear as mud?
David?
# PSI Length Hole dia
412 65 0.88 0.453
413 65 1.25 0.453
414 65 1.50 0.453
415 65 1.75 0.453
418 65 2.00 0.453
423 65 2.50 0.453
415 65 1.25 0.625
425 65 2.00 0.625
