ot:sand spurs, how to get rid of them?
wfw
we now live on the nc coast and have sand spurs in our lawn. does anyone know how to get rid of them If I round up them it leaves a brown spot in the lawn. weed-b-gone will not kill it as it is a type of grass. I have been puling them up by hand but you will miss some and if not careful get stuck by them.
frank
Frequent mowing and spot herbicide for most pesky plants- a local pest likely has some specific treatment available known in area- check the local garden supply places or local landscapers. Teasing Alert!. Could fence in the yard and get a couple Shetland sheep for weed and feed. Get tiller out, churn up whole yard and plant White Dutch clover and forget about mowing more than twice a year. Or till and plant Winter Wheat now with overseed clover in spring. Then get water bucket for the sheep. RN
Similar to our ' Three J's ' they are called that because when you step on one with bare feet you often yell out J...., J.... , J.....
When small the easiest way to kill them is with an electric jug of boiling water . Pour about a half a coffee mug onto the roots , takes about two days to wilt and die . No residual effect and surrounding grass moves in to cover the gap fairly quickly .
A product called Amaze. Put on in February and no more sand burrs, Again the next Feb. no more burrs.
Two years and they are gone.
2-4-D should kill them without killing your grass. Now is a great time to spray your yard. The weeds will take the 2-4-D into the roots preparing for the dormant winter season.
Have your ground analyzed and they will tell you how much lime the ground needs. Sand burrs don't like sweet ground.
