My one ton flat deck has Grote tail lights...real truck style with 4 wire connectors ( I can get the part number if it matters). All was working well, but the bolt housing broke off one and it was dangling and obscuring my licene plate.
It still all functioned but I got pulled over and was told to replace the whole unit. So a month later it still is hanging and working...but I order the proper replacement light. A couple days ago sudenly I loose all blinkers and four way flashers. The marker lights still work when the head lights are on.
I figure time to put the new unit on. Unfortunatly there is no change. I only have the running lights or marker on when the headlight is on. No flashers or turn indicators or brake lights.
What am I missing here? Grounding issue? But where should I start checking and why would the running light work but nothing else if there is a grounding issue.
I did try the old one back and it still was the same.
Any advice would be appreciated. Thanks Grant
