Tony in WI
New User
I seen the tip of the day was on removing a bearing race and I thought I'd share how we removed a needle bearing in a shallow blind hole with grease. A customer brought a solid steel high rpm 6ft long roller to me to turn a crown on the OD for belt tracking, but first I wanted to get the needle bearing out of the ID on the end of the roller without damaging it. The bore was only slightly deeper than needle bearing (blind hole) so my welder says we can use grease. He packed the bore full of grease and put a shaft in the ID of the bearing that was slightly under the ID then struck the end of the shaft with a hammer, sure enough the needle bearing slid out after a few swings. I thought that was pretty neat solution! I'm sure this has been around and in use for years, but it was a first for me so please don't bash me too much in replys
