sears planer
bfullmer
Bought planer at auction sears model 113 21800, any one have a manual for it ?? sears is no help,cant figure out adjustment knob ??
Thanks for your help, found parts diagram I
Am missing a collar and washer of course no longer available fr sears but I think I can find a 1/2 collar with set screw
The only adjustment on that jointer you should use is raising and lowering the front table to increase the amount of wood you cut off. It is the knob under the front table. Under most circumstances the front table should be about 1/16" below the rear table. I can't find info on that jointer if the rear table is adjustable. If it is the rear table should be level with the cutting edge of the knife.
Looking for a knob- looked at pages of knobs can't find one that slides on a 3/8 shaft and then tightens up with a set screw guy a granger didn't have a clue
