So I found another hoist, a Yale & Towne, lever type, "Yale & Towne Pull Lift PL46C" 3 ton model, but it seems there may be a problem, seems to ratchet ok, but I think the load brake is not working. Something is awry. Not sure if the seller will take it back, for the money its not worth the hassle, but comparable new models cost significantly more, like over $1000+. So off to Harbor Freight I go for one that works, and is much less costly, so I can get my darned tractor un-stuck, or at least the mower away from it! I think given its dried out and its not in suction and just touching the differential, should work fine.
The below link shows must be a newer series, but it does look identical, the gear case on it, appears to be the same, I guess the only difference is the block whereas the chain passes through and is pinned off on the case, 2 part line is it ?
Are these serviceable, can you get parts and repair these? I'm well aware of safety aspects of it, next option once I know if it's a boat anchor is, contact the seller, tell him it was a dud, see if he what he does, nice people, gave me half a dozen fresh eggs, accepted my lower offer on it. It was advertised as a working unit. Probably the first time I've been burned on a CL buy, next time hang the unit and demonstrate it, though it did ratchet fine, problem is, when you hang it, you can get it to pull, but on the reverse stroke the chain goes back to the original position, so essentially it has not moved, something needs to hold it while you ratchet back to the next pull stroke.
I did notice 2 check valve like balls, spring loaded on the projections of the case, I assume those are for oil or lube and know you don't want any of that on the load brake, there may even be one on the block, looks mashed or peened, saw a small circle on it.
Any advise greatly appreciated and thanks for the post on 6-14 from "Charles (in GA)" providing the links to the current manufacturer or owner "Columbus McKinnon Corp" after looking its where I found the below manual that looks identical.
Some photos
Yale PC PD ratchet hoist
Some photos
