Jimmy B.
New User
I have a 1940 9N Ser# 9N19265 No 3 point I have R&R the hydraulic oil it had water in it, I put air to the hydraulic dip stick to prime the pump, still no 3 point and now have a hydraulic leak coming from the small holes in bottom of tractor, I also noticed I can lift the 3 Point arms with my hands with no resistance is this normal ?
Do you have the PTO engaged??? The hyd pump is driven off the PTO and by the way you can blow all the air you want in the dipstick hole and never prime that hyd system because the pump sits in the oil. Sounds like you need to buy a I-T FO-4 manual
Yes I do have it engaged pto shaft spinning fine, should I be able to lift those arms with no resistance ? And thanks for your reply!
Yes the system is gravity down hyd power up so you can lift those arm pretty easy. Sounds like you need to pull the inspection cover off the one with the dipstick and have a look inside with it running to see what is going on
I am about 7 miles south of Camdenton out close to the Air Port. My e-mail is always open on here and I do mobile repair stuff
