three point pin name
I am banging my head against the wall trying to remember the name of this part so I can find one. This is the pin that goes into the lift arm through the rod to the upper lift arms. It is 5/8" diameter by 2".
"Lift link bottom pin".
Had you told us the make and model of the tractor in question, we could probably come up with a part number#!
Case/IH PART #86400412 clevis PIN W/ Cotter pin to secure it. $9 plus or pick up your 5/8 pin at hardware store for less. Generic pin may not be same hardness as OEM and wear a little quicker but probably a lot cheaper.
I was sure it was a Kubota- the extension latch on the right of the photo, and the sway bar setup, are exactly the same as my MX5000, right down to the shape of the pin on the sway bar.
