Glennster-2008 Impala
Mark-Ia
Glennster, I'm working on a 2008 Impala that slid into a light pole. Do you have the dimensions from top of rear strut to the other? Thanks, Mark..
mark the rear top of strut tower measurements as follows. there are 3 bolts on the top of the towers.
tip of inner two bolts.....1002 mm or 39 and 7/16 inch
the bolts closest to the rear bumper
1159 mm or 45 5/8 inch to the tips of the bolts.
at the upper rear body panel sill (top of deck lid) inner seam at pinch weld...829mm or 32 5/8 inch. if you need any other specs, let me know.
