glennster
put one of the chains back on, and hit it with the impact. spun that thing right out. about the size of a shallow 5/8 impact socket. the inside has threads in it that screws on the end of the drive motor. the snap ring did nothing, as well as the splines. i suspect the double sprocket was also used to drive something else too, thus the splines. got to get a bearing splitter and puller on there and pull the sprocket off, then i should be able to get the drive motor out of there. never saw a nut like that before!!! heres a couple of pics.
crazy looking nut
<a href="http://photobucket.com/" target="_blank">
</a>
heres one of the original photos
</a>
thanks everybody for the help!!
crazy looking nut
