glennster
wayne, i know you work on a lot of heavy equipment, need some advice here. i have an older prime mover skidsteer, l1200 model. i need to remove one of the hydraulic drive motors to get rebuilt. the manual says to remove the nut that holds the drive sprocket off the motor, torque is 300 ft lbs. but i cant get to the nut. there is a steel "cover" over the access for the retaining nut. it has a square hole for a 1/2 inch rachet. there was a circlip on the outer splines, but removing it doesnt do anything. somehow i need to get that square drive cap out of there. any ideas?? heres a couple pics. the drive motor is a ross trw mae24029.
<a href="http://photobucket.com/" target="_blank">
</a>
</a>
