wheel balancer post, author Glenn FitzGerald
Hi Glenn, Would it be possible for you to measure it so that i could make one. I would need the Outside diameter and inside diameter, thickness and what bolt patterns are on drilled in it. i.e 8lug and 6 lug pattern? are there some kind of bolts with it?
Thanks Much
Mark
Mark is this for a bubble balancer, if so I think I have 1 left over from my tire shop days. If I can find it you can have it for the cost of shipping. Can ck tonight and see if I can find it.
Hi Hd6gtom, Yes it is for a bubble balancer and if you have it i could use it and would greatly appreciate it.
Thanks Mark
I did not get home till after dark last night, will look for it this afternoon and post back on Monday when I get back to work. This 1 is also made of aluminum, has the bolts with it, now if I can just find it.
Mark I found the adapter. It is for the 6 and 8 bolt pickup rims, standard bolt pattern, not metric. Get me your address and I can tell you the shipping cost. I will be leaving for Mount Pleasant Iowa Wednesday morning (OLD THREASURES REUNION) and will be gone till 9-2-14. We ship daily from home. I am at work now and I will check back here later today and will be at work From 8:30 to 5:00 tomorrow.
Mark I will be leaving for The Steam show Tomorrow morning, will be gone till 9-2-14. I will try to remember to post back to you when I get back. I have it here at work and will not have access to internet till I get back.
