I bought a Eastwood 135 wire welder from a local auto body shop, it was used with flux wire only but has gauges for a tank.
I couldn"t find a used Lincoln so I hope this band
is ok, also I have read using gas instead of flux wire makes welding thin steel easier, Is this correct? I have 2 stick welders for heavy stuff but as newer thing are made with thinner and thinner metal I need to be able to weld really thin stuff.
