Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
JD 1050 Hour Meter
njs458
08-15-2014 12:27:35
What action(s) could have turned the hour meter back to zero?
smallercrawler
08-16-2014 14:22:14
 Re: JD 1050 Hour Meter in reply to njs458, 08-15-2014 12:27:35
WAG: could meter have been wired to run full time and stopped at 0's; then disconnected?? How many digits, 3+1/10?
mark
08-15-2014 20:04:52
You entered The Twilight Zone?
njs458
08-16-2014 04:11:24
 Re: JD 1050 Hour Meter in reply to mark, 08-15-2014 20:04:52
Recently bought this with 300 hours on the meter. Looking thru the history of repair n maint., I found an entry of work done at 475 hours. That would mean that there is really 775 hour on this 1984 tractor. That is why I asked the question. There is no indication that the meter was replaced.
If I subscribe to your T Z theory, there could be 1000's of hours on it.
mark
08-16-2014 07:01:24
 Re: JD 1050 Hour Meter in reply to njs458, 08-16-2014 04:11:24
My comment was tongue-in-cheek. I don"t think an hour meter can/could run backward under any normal circumstances. I had a 1050 several years ago and it was a good machine but not perfect. Brakes were a constant issue and expensive to replace It was too light and had no power steering. The positives were lots of power for it"s size, seemingly ran on fumes and had the most ideal gear ranges. I used it mainly with a finish mower to mow 2 acres of grass and to work the garden. I sold it 9 years ago for $5k and it had 1499 hours. I see them selling for that and more now and many have thousands of hours on them.
njs458
08-20-2014 14:10:20
 Re: JD 1050 Hour Meter in reply to mark, 08-16-2014 07:01:24
I went to check the odometer digits and there are 4 digits for hours and 1 for tenths. Much to my surprise it read 803.2! How this happened I have no idea. I truly believe that it is the correct hours based on maintenance logs.
Copyright © 1997-2015 Yesterday's Tractor Co.
