Re: Onan generator mocroquite 4000
Billy Shafer
I would add some gas cleaner to the fuel.Let in run on that mixture for awhile. Pulling the carb on that model can be a real pain.Also check your oil level. On some models Onan used a low oil level shutdown switch. Caused so many false shutdowns. Onan dropped it. If you will post a full model and serial number. I can tell you if you have the switch.
You need to run it at least once a month. To keep the carb cleaned out and the system in shape.
