On this hydraulic cylinder I had one of the ports leaking. A half inch pipe thread fitting was put in a o-ring fitting hole. To weld a new one on I had to take the cylinder apart. Might as well rebuild it while it is apart.
On a piston as pictured when you buy a seal kit do you get the correct number of seals in the package or is there extra if your piston does not require as many as in the package. As you can see I have two extra, each side had three seals on it, and I had four in each package????
