I have a quad 300 and it has been a very good one. Has a scope with 5 lines to give you 10, 20, 30, 40 and 50 yards lines. I have shot many a deer with it over the years.
I bought a Barnett Vengeance last fall and like it as it seemed better balanced if you had to hold it for any length of time. The only bad thing I could say was their scopes that come with it were very poor quality. I got three before I got one that was clear and then that one the cross hairs were at a 45 degree angle. Finally gave up and bought one from Cabelas.
Old:
Is that a "standard" bow or a Compound ? Also, for hunting purposes, what is the best type of Bolt to use - Aluminum, Fiberglass, WHAT ?
Doc
It is a compound type. I use aluminum bolts in it. The broad heads are a 3 blade that match the flecthings (sp). I have to date taken down a good many deer with it but the draw back is it is over 8lbs so heavy to carry
Old:
Your's can't be any heavier than mine. Way back in 8th Grade Metal Shop, I made a Crossbow out of an old rifle stock & an old car leaf-spring. It uses piano wire for a "string" and the Bolts are solid steel rods that are threaded on both ends for screw-on tips & fletchings. Silent but deadly, doesn't spook the Game the way a firearm does. Haven't used it in many, many years. Got it in storage & can't even remember exactly where it's at right now. LOL!
Doc :>)
