12v LED travel trailer interior lights follow-up
woodbutcher
I ordered 7 of those things from Amazon. They look just like the ones in the trailer. They arrived today. I installed one, and it did not light up when I pressed the switch. I tested two more, and they would not work, either. I"m repacking the whole order and returning it. Does anybody know of a source for LED lights that work?
Butch
A local truck stop will have what you need. I use this on all of my trailers so when I'm on the road and have a problem I can get parts.
Thanks for those replies. I had not considered looking at a truck stop. Also, I guess it's possible I was trying to connect them backwards. I'll try the other way and see what happens.
Well, I went back and tested these backward and forward, but it didn't make any difference. They don't work. I think they are just more Chinese junk.
Butch
NAPA has some VERY bright spot lights in store. They are almost 60 bucks each but man are they bright!!!!!
I put a couple of these in the forward cabin on my boat to replace some 20W halogen lights. Seems like I get almost the same amount of light and they only draw about a quarter of an amp each. I've had no problems with them, they've been on my boat for about a year. Boat is in saltwater, but that's not important as the cabin is dry.
LED 12 volt reading light
Thanks to all for the replies. One post referred to tower bulbs, and I did not know what that meant. So I went to eBay and looked through the ads. There they were. I ordered four to replace some of the heat-producing incandescent bulbs. The ones I ordered have 42 SMD. They are just right to replace the lights that were there. I'm happy.
Butch
