While this is not really directly tool related, many tools will come into play on the issue I face. I have a vehicle which is approx. 27 years old which has a little over 5,000 miles on it, always garaged, and in very nice condition. Issue I face is todays fuel has litterally rendered it inoperable, and it has not ran in several years now. I moved and trailered the vehicle when I moved it (would not run), and that was in 2003 which gives you an indicator of how long it has been since it was actually started. I am planning on selling, and plan on doing what it takes to clean out the fuel system. Has anyone faced a similar scenario involving a newer vehicle? I have done this on small engines, a tractor, but nothing involving an emission controlled vehicle such as this. This vehicle is one of the last V-8 rear wheel drive with a 4 barrel carb on it, so no injectors, etc on this one. Right now my plan is to remove fuel tank, and either soak or have "boiled out", rebuild carb, probably replace fuel pump. Any suggestions? This is somewhat of a rare, low production vehicle which means it has significantly higher value to a buyer if it remains as it is in regards to carb, etc., and runs "as if it was new". Thanks in advance.
