Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Re: Help on scanned codes on my Sierra
4play
07-25-2014 22:48:15
P0171 would not generate from a thermostat problem, incidentally there are certain codes that can set due to engine temp/thermostat concerns, especially when they are stuck op and running too cool.
P0171 means the engine (bank 1) is running too lean, lean to the point where the PCM attempted to add extra fuel and reached its limit of compensation and its still too lean. Vacuum leaks (vac lines/hoses, intake gasket etc are usually the culprit but a fuel supply/delivery problem often cause problems too among a few other things.
The p0138,p0158 are for the rear oxygen sensors behind the catalytic converters (after cat) indicating excessive voltage. Possible causes are faulty cats, shorted/melted sensors or wiring.
The p0420,p0430 codes generate from the rear sensors too. These codes trip when the PCM sees the rear sensors mimicking the front sensor switch rate which means the cats are not cleaning the exhaust emissions to a specific level. Most likely cause is the catalytic converters. Often times driving a vehicle with excessive misfiring can burn out the cats from excessive heat generated from unburned fuel.
The p0300 is typical when an engine simply runs rough and not on a particular cylinder or random. Many things can cause this from typical tune up items, sensors-ignition, mechanical problems, fuel problems, sensors, among the same things listed above with p0171. Since you are taking the dist cap off, verify the rotor or dist shaft does not have excessive play when turning back/forth. I have seen a few of these trucks with worn gears on the dist, also some worn dist shafts too.
So, basically I would try to look into the P0171 and P0300 running problem first, the other codes maybe related to the running problem from these two codes.
Sorry for the long post, I dont want to add more right now but if you check some stuff out then repost and maybe we can help narrow things down.
