Yesterday's Tractor Co.
Shop Now View Cart
Tool Talk Discussion Forum
Re: Ford Jubilee 1953 8N- Battery and tool box
07-25-2014 15:33:29
the first thing we need is to correctly identify the tractor, there is no such thing as a jubilee 8n, if its a 1953 year model its a golden jubilee naa, which is a completly different tractor than a 1952 back 8n,9n, or 2n, and takes a totaly different tool box, in a different location, as for a 8v battery some people do that but if you do the generator must also be modified to charge 8 volts otherwise it will only charge 6 volts, other options are to make sure all connections are clean, bright, and tight, then a 6volt will easily start the tractor, or convert it to 12 volt negative ground which can be done but it takes a alternator and some rewiring
Frank Castro
07-26-2014 06:38:30
 Re: Ford Jubilee 1953 8N- Battery and tool box in reply to ericlb, 07-25-2014 15:33:29
Ok, I looked at the tractor and it says Golden Jubilee model 1908-1953 on the front of the tractor. On the engine it says 6015-F, 36D12 A. Does this help?
Frank Castro
07-26-2014 06:31:15
This May sound stupid but how do I find out what kind of tractor it is (model Number? Is it written on the tractor some where?
I nixed the 8volt battery.
