TractorLinks.com
Tool Talk Discussion Forum
Ford Jubilee 1953 8N- Battery and tool box
Frank Castro
07-25-2014 15:15:31
I just purchased a 1953 Ford Jubilee 8N. It looks and runs great. I believe I need a new battery because this one does not hold charge. I assume it is the right battery in there. My question is does anyone know what the specs are for the battery? I know it is a 6volt batter and the tractor is a positive ground. My neighbor told me I could put an 8 volt battery in there and it would give it more juice. Is this true? Would that hurt my tractor? Also would like to know if anyone can recommend where I can get a tool box for the tractor? Thanks
Frank :?:
Cliff(VA)
07-28-2014 06:33:10
 Re: Ford Jubilee 1953 8N- Battery and tool box in reply to Frank Castro, 07-25-2014 15:15:31
If you have a Jub, the toolbox is in the running board. You can buy replacements at the link below.
Cliff(VA)
Charles (in GA)
07-26-2014 07:45:37
People are prone to taking Golden Jubilee emblems and installing them on 600's. If you are not familiar with the various models you could have wound up with something like this.
One easy ID is to look at the rear axles. in the center of the wheel, the NAA/Jubilee has a large nut and cotter pin, while the 600 series has a bare axle end. The Jubilee has a hub and axle shaft separate like the 8N and earlier, retained with a nut. The 600 and later uses a one piece axle shaft and hub like on most automobiles and light trucks.
Charles
old
07-25-2014 20:52:47
Best figure out what you have before you do more. At best an 8 volt battery is a band aid fix for other problems since the generator will not keep it charged and when was the last time you found an 8 volt charger.
That said the 8N was made from 1948 to 1952. The Jubilee was made in 1953 and a totally different modal tractor. The 8N was a flat head engine the Jubilee a valve in hard engine
soundguy
07-25-2014 16:58:27
them 8n jubilee 1953 tractors are so rare.. in fact. so rare exactly 0 were ever made.. so kinda hard to give you much advice!!
both would be 6v +grnd.
8v bats are only a source of problems, as the generator/regulator is set to charge a 6v battery.. thus leaving you with a near dead 8v battery soon.
better to fix the 6v system or move to 12 vs trying to go 8
tell us which tractor you have.. an 8n or a naa and we can get to generator testing. there was a field circuit setup change in the charge system between those 2 models .. they test and polarize differently
showcrop
07-25-2014 16:57:10
Never replace anything without a definitive test. I thought that I had a bad battery because it seemed to not want to hold a charge. I took it to my local independently owned auto parts store and got it checked and it checked out good despite being 9 years old. I believe it is a Douglas, and they went out of business due to lack of repeat sales.
Charles in Aus.
07-25-2014 16:17:03
Different tractor but the theory is the same , try making sure that the lead to earth [either positive or negative] goes as close to the starter as possible . Makes for a much easier pathway for high starting current .A big fat cable with well crimped or soldered ends really helps , especially with 6 volts .
http://forums.yesterdaystractors.com/viewtopic.php?t=1151090&start=15&sid=01a7c3dae7b103949c42e25f6a36d487
Gambles
07-25-2014 16:08:03
Just thought I'd chime in about the 8 volt battery. First, if you can find them, they are expensive. If you ever need to jump start it, or use it as a jump starter, it really just doesn't work too well. If the system is 6 volts, keep the battery cables and clamps clean and forget the 8 volt battery.
ericlb
07-25-2014 15:33:29
the first thing we need is to correctly identify the tractor, there is no such thing as a jubilee 8n, if its a 1953 year model its a golden jubilee naa, which is a completly different tractor than a 1952 back 8n,9n, or 2n, and takes a totaly different tool box, in a different location, as for a 8v battery some people do that but if you do the generator must also be modified to charge 8 volts otherwise it will only charge 6 volts, other options are to make sure all connections are clean, bright, and tight, then a 6volt will easily start the tractor, or convert it to 12 volt negative ground which can be done but it takes a alternator and some rewiring
Frank Castro
07-26-2014 06:38:30
 Re: Ford Jubilee 1953 8N- Battery and tool box in reply to ericlb, 07-25-2014 15:33:29
Ok, I looked at the tractor and it says Golden Jubilee model 1908-1953 on the front of the tractor. On the engine it says 6015-F, 36D12 A. Does this help?
Frank Castro
07-26-2014 06:31:15
This May sound stupid but how do I find out what kind of tractor it is (model Number? Is it written on the tractor some where?
Thanks
I nixed the 8volt battery.
