Donald Lehman
A little while back I asked some questions about the things and got some straightforward answers. So I bought one of the attachments. Once you get the hang of oprerating it it works pretty good. The first few times I used it, it was almost as much work as doing it by hand, but the more I use it, the better I like it. A side to side motion works well and if you hit a well rooted weed dragging it backwards over the roots a second time will tear them up pretty good. In the long run, once you get the hang of using it, I think it is less work than a hand cultivator.
Biggest surprise was that the cultivator attachment cost as much as the weed wacker itself.
The wacker head uses one piece of the sting that slides in and strings both sides at once. It's a simple matter to change. Works quite well for a cheapo Murry so far.
Thanks for the info guys.
