TractorLinks.com
Tool Talk Discussion Forum
Re: Engine Run-on after Shut-off
David G
07-24-2014 19:54:20
There is a big difference between an engine that stays running due to ignition staying on, and run on (dieseling), and you can tell by the sound and smell.
Run on will knock and stink.
Milan
07-24-2014 20:01:49
 Re: Engine Run-on after Shut-off in reply to David G, 07-24-2014 19:54:20
David, when I owned this vehicle that had this problem, and it was diagnosed as being the alternator, it had the exact same characteristics as dieseling.
I think it was hitting on only one cylinder, knocked like it was destroying itself, and the exhaust did stink like you said, because the other cylinders were not firing.
Putting it in drive would kill the engine, as well as leaving it in park and depressing the gas pedal.
Point was, it was feeding "some" voltage back into the ignition circuit, but only enough to fire one or maybe two plugs.
David G
07-24-2014 20:08:19
 Re: Engine Run-on after Shut-off in reply to Milan, 07-24-2014 20:01:49
I would assume that it was feeding power back to the idle stop solenoid and holding that open, not the ignition.
Milan
07-24-2014 20:16:25
 Re: Engine Run-on after Shut-off in reply to David G, 07-24-2014 20:08:19
Well, in just the last hour or so I have found several forums where it is said that the simplest way to confirm is to remove the hot wire from the coil while the engine is doing it's run-on thing.
The folks posting on those forums say that when this is the problem (alternator being bad) that removing that wire kills the engine immediately.
I found one site that said that the problem is one diode in one of the tri-packs of diodes had shorted, simple as that.
The alternator continues to function at a reduced capacity and the car shows no other symptoms.
It would seem to me though, that if the engine stopped with the points closed, that it would run the battery down overnight, but, in my case I ran the vehicle daily, did not have an ammeter and did not know if it partially ran the battery down.
David G
07-24-2014 20:27:12
 Re: Engine Run-on after Shut-off in reply to Milan, 07-24-2014 20:16:25
We need to first find out what his symptoms are.
There is NO way to get dieseling from an alternator feedback problem.
A lot of forum posts are from people that really do not know what they are talking about. I looked at one tonight on this subject at a racing forum.
Milan
07-24-2014 20:38:51
 Re: Engine Run-on after Shut-off in reply to David G, 07-24-2014 20:27:12
David, I never said that an alternator feedback problem would cause dieseling.
All I am saying is that I had a problem with a vehicle doing this thing that resembled dieseling in every way, shape and form, and it was actually running on one or maybe two cylinders.
It knocked, smelled terrible, and so on.
Had all the symptoms of dieseling, except that I could start it cold, run it for only two or three minutes and it would do it.
And, in my case, replacing the alternator fixed it.
I share the same sentiments as you expressed, with many posts on many forums. However, the mere fact that someone here (me) says it was the cause of a similar problem as the original poster described, and both you and I have found references to it on forums this evening, should make you go "Hmmm, maybe there is something to this.".
Dean
07-24-2014 19:59:00
Bingo.
Dean
