A few odd tools, identify?
MeAnthony
Cleaning up the neighbor lady's garage, came across a couple strange things. Anyone know what they are?
This one says Medusa BrickTite(I think) on one side and Medusa StoneTite on the other side.
Her grandpa had sheep, so I'm wondering if the funny comb-looking gadget is related to that? One fin toward the middle, 4th in from the handle, looks smooth(which makes no sense to me) whereas all the others are serrated.
The little level says Stanley on the top front, patent Jun.23.98 on the bottom front. It has a thumbscrew and two little bumps on top, looks like it's supposed to be clamped onto the edge of something?
Thanks,
Anthony
This was referred to as a "Lining Comb" during my 4-H livestock showing days. We used them on beef cattle to give a spiffy hair-do before the show.
Lining comb I/we used only had four lines of teeth and the handle was on the back side.
This one looks like something you would use with wool to get the strands all lined up??
My guesses: #1 is driven into mortar joint as brick/block is being laid to hold string line, was replaced by the small notched/grooved wood blocks, again superseded by lasers.
Next may have been used as a curry comb on the animal, or as a card to comb and orient shorn wool strands.
Level can be attached to carpenter's square to set slopes on rafters and stairs.
(quoted from post at 16:28:54 07/20/14) wool card is what we called it.
Teeth are no where near long enough for carding wool. ours had very stiff wire about an inch long. and the wool never wore them down.
