John Deere 4640 Transmission problems
Dr Dawgs
New User
Don't have gears 1-4 forward....Is it possibly something other than clutch packs?....checked some pressures...seem ok but....not sure if forward 7 is working...in same group or cluster
There are some transmission wizards on the JD section of this
site.
Was the injection pump dialed up? Number of hours?
Ballasted duals? Sudden fault or gradual? Do you have the
service manual?
(quoted from post at 10:50:45 07/17/14) There are some transmission wizards on the JD section of this
site.
service manual?
have the service manual.I just purchased this tractor with this problem.the odometer says 2847 hoursbut it may have turned over.it is a PowerShift transmission.are you talking about the hydraulic pump or does it have an injection pump?ballasted duals?
